GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Fantastic.  Thanks for posting the solution/fix.  I changed my cell phone date to 2/1/25 then went through the steps to add my 2nd gen Chromecast to my Home app.  My Chromecast immediately began downloading updates.  Afterwards change my cell phone back to auto-date.  My Chromecast completed the update and boom, I can cast again.  THANKS SO MUCH.  Google should send this to everyone who has performed a factory reset.
Olá! Eu fiz a redefinição de fábrica, acabei de fazer o que você postou aqui e deu certo, meu Chromecast já está funcionando! 👏🤘😉
    >> If you performed a factory reset during your initial troubleshooting, you'll need to do this.....
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
TWY
Hi - how much longer till it's fixed?
**** If you performed a factory reset during your initial troubleshooting, you'll need to do this..
Pride79
When can expect a fix to this problem. This is only way i have of casting to be able to watch tv so I'm paying for streaming services I can't even use rite now
    >> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Andrew_Quee
Thanks Google, the patch worked perfectly.  See you in another ten years for a new certificate.
JitSujittra
We had performed a factory reset, please advise how to resolve.
Scroll down to Johnnyzero2's fix or my one. They both work . Rank the comments from newest to oldest to make your job easier
Ambi1
Se han demorado muchísimo. Estamos hablando de google no de un emprendimiento... me parece bastante sospechoso este "error".
 >>>>> If you performed a factory reset during your initial troubleshooting, you'll need to do this..
Shopraket
Thank you very much! Just got working again after a week
Nathalialst
Temos uma solução para os aparelhos resetados? Alguém já conseguiu conectar?
AndreFla90
Eu não sabia, por isso restaurei de fábrica, poderia me ajudar no backup ou reconfiguração?!
Rudineir69
I need help, because I already reset my Crhomecasr for factory.
 -->> If you performed a factory reset during your initial troubleshooting, you'll need to do this..
Rtmaciano
Hoje, reiniciei novamente o chromecast,  apenas tirei do wifi e coloquei novamente e funcionou.  Até que enfim está funcionando.
johnnyzero2
For all the people who performed a factory reset during their initial troubleshooting, this procedure will allow you to reconnect your Chromecast to your Wi-Fi network, so that it can receive the firmware update fix that Google started rolling out on 3/13.
1) Temporarily set the date on your smartphone (or tablet) to March 7, 2025 or earlier. If you don't know how to do that, see below.*
2) Use the Google Home app to re-setup your Chromecast by adding it as a new device (+). You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Most importantly, it'll now be reconnected to your Wi-Fi network so that it can receive the firmware update fix.
3) Change your phone's date/time setting back to Auto now.
4) Sit back and wait for the firmware update from Google to be installed. This should restore your Chromecast to full functionality.
Note: Supposedly it's being done as a "phased rollout", so it could take a while for the firmware update to hit your Chromecast. Also, some have reported that power-cycling your Chromecast (unplug/re-plug the power cable) will sort of "provoke" the firmware update to be installed. Patience.
*How to change your phone's date/time settings:
For iPhone/iPad: go to Settings, General, Date & Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
For most Android phones/tablets: Settings, General Management, Date and Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
**Google REALLY should pin this information to the top of this page.**
Daty
Fiz os procedimentos de alterar hora, ele conectou wi-fi mas  antes de finalizar ele não termina a atualização. Como proceder?
Imbossy71
Hello all! I'm new here. So I can't send this app to my TV? Sorry, I'm a layman.
Renan12
Precisamos passar por essa humilhação...? Realmente precisamos é processar o Google, por não dar uma solução para o ocorrido e o transtorno todo gerado.
jjsp
it is a shame at you
most people have reset the device
when will it be fixed?????
SanoLanO
What works for me after a factory reset:
Set the phone’s date to 2025.03.01 and set up Chromecast as usual.
JoeyLee
My Chromecast started lagging on Saturday March 15. On Sunday, I can't get any of my subscriptions and YouTube keeps lagging with the rotating circle. Should I buy Roku or Firestick instead? Really enjoyed my Google service before.
Ckiser300
Please contact to Wi-Fi
johnnyzero2
***Google REALLY should pin this information to the top of this page.***
Thank you so much! I did it and it really works! THANK YOU!
Sc64
Thank you!!! It worked.
Julia7
Yo sigo esperando que me ayuden porque si restablecí la configuración de fábrica! Espero que tenga alguna solución!
