What is Matter? Read more
The message you are trying to access is permanently deleted.
The latest updates from Google Home and Nest Read more
Hi all, I’ve been having a persistent issue with my Nest Doorbell (Wired, 1st Gen) and automations in the Google Home app — both before and after migrating the doorbell from the Nest app. The doorbell shows up correctly in Google Home, and doorbell p...
Private Router
Even though I set it for directions to be audible, I never heard any kind of guidance. In addition, Chrome had misinformation about whether businesses were open or closed. I knew a particular store was open, so I put in that address but the app took ...
What is very weird is after it shuts off for several hours, it comes back on?! That doesn't make sense... unless the unit has gone fickle. The same generation in another part of our home works just fine. I've reset the nest, unplugged/replugged the r...
Trying to use THERMOSTAT. Wanted to download app on Iphone, but it says ( APP NOT AVAILABLE in your country or region ). I am using UKRAINIAN Apple ID !! Called support. Problem was not solved When ?? I can expect to be able to download app from Appl...
We just had a new Nest thermostat installed. It has power but no wifi. We got to the point where the display said no wifi but it allowed us to change the temperature and operate the a/c. Minutes later the display changed to a circle and said "connect...
I would like to enable (people) events on my outdoor camera only at night, to save the battery. However, I can't find a command in the script editor docs for enabling/disabling camera events. Is this possible?
I'm trying to add an automation and the Google Home app is making this impossible. The buttons are all being rendered outside of the app area and are unclickable. It doesn't look like I can attach screenshots here, so here are some Drive links: https...
My goal is setup an automation that would be triggered at 7 pm every night and stream the camera feed of our nursery crib camera on to two nest hub max.What works:- The cameras are made by Ubiquiti and I have him integrated into the google ecosystem ...
I had to change my router and after restore almost everithing worke good except Google Home, individually I was able to connect al the apps, but when I try to connect the apps with Google Home the app is not letting me connect anything, my alarm work...
