Sensor detecting movement
Leedsed
Hello, I inherited a Nest in a house I moved to. One of the features I was really enjoying was that it appeared to have some sort of sensor that knew when I was away. It even turned off the heat when I was sat on the sofa say, watching a film for a long time. Unfortunately that seems to have stopped working, so now if I forget to turn the heating off I come home to find the heating has been on all time, or (like just now!) I wake up too hot. I’ve tried turning off the program completely, but that hasn’t changed anything. Can anybody offer any advice how to make the sensor operational again so it knows when I am (for example) in bed, so it switches off the heating if I forget.
David_K
If you manage the thermostat in the Nest app:
Learn more about Home/Away Assist - Google Nest Help
If you manage the thermostat in the Home app:
About Home & Away Routines - Google Nest Help
8 REPLIES 8
David_K
Leedsed
Thanks very much. I've made some changes and had a read on it. I'll come back if I have any more problems, but hopefully that will solve it.
EdwardT
@David_K, thanks for the help!
@Leedsed, how's it going with your Nest Thermostat? Still need our help?
Edward
Leedsed
I've changed the settings and will monitor it. Thanks for checking in.
I wanted to check in and see if everything is good to go from here. Please let me know, as I would be happy to assist, and answer any questions you may have.
Leedsed
Hi Jake, no I'm fine thanks. I've played around with the settings as David recommended, but also have turned the timer off, so it will for sure never heat when I'm not arround again. Than ks for checking.
I am glad to be of help. With you being good to go, I am going to go ahead and lock the thread at this time. If you have any questions from here, please feel free to create a new post.
