Device help or recommendation
Bki-in-SC
I moved from Simplisafe to ADT, and received Google Home as part of the installation.
I have a GFI circuit in my garage, into which I have plugged a freezer.  Often enough, a rain storm passes through, and the circuit trips, leading to the freezer losing its power.  I need a device to put on the circuit that will cause the assistant to notify me when the device is not powered.
Any ideas or recommendations?
Thanks in advance.
David_K
One I know of is called iSocket.
Power outages alarm device for USA - texts or call your cell phone
This isn't an endorsement or recommendation.
