nest protect battery vs. hardwire
clarebear
i have next protect BATTERY versions. Can I adapt them to be hardwired or do I need to buy new ones?
David_K
You can't adapt them to be hardwired, they simply don't have the hardware to be wired. Wired models have a power connector on the back, whereas battery models do not.
Thank you
janthadeus
Thanks for chiming in, Edward.
janthadeus
Checking in — I'm glad that davidking answered your question. To make sure, do you have other questions or concerns?
I appreciate the help, davidking.
EdwardT
Hi clarebear,
Edward
