Heat Link is eligible for a replacement by Nest
ig_613
My thermostat’s Heat Link is eligible for a replacement by Nest, but unfortunately BOXT are not in Northern Ireland.
I currently have no heating
Can someone please advise ASAP
@everyone
David_K
I'd recommend that you contact the Google Nest support team directly about this.
  1. Go to Contact Us - Google Nest Help
  2. Select "Thermostats", type a brief description of the issue, then click "Next".
  3. Click "Other", then click "Next step" until you see the contact options.
  4. Choose to get a call or call or chat with the team as available in your country.
LarisaL
Hi @ig_613, thanks for reaching out! We're so sorry to hear about this situation. Did you manage to contact our live support or do you want to continue here?
Thank you, @David_K for your help!
Many thanks, Larisa
LarisaL
Hi there, just checking in! Did you see the message from above?
OannaCG
Hey there, since we haven't heard from you for a couple of days, we'll close this thread for now. If you still need help, let us know so we can continue. Thanks!
