09-29-2023 05:54 AM
I've seen a couple of posts on here like this but the two I've looked at had resolution by purchasing a new Heat Link...
The Nest thermostat went blank and the electrician who fitted it came and had a look. There are no lights on the Heat Link (3rd Gen I think) but he tested that there was electricity wired into it. I tried holding down the button on the front for 30+ seconds - nothing...
Is it fried? Do I need to purchase a new one and if so where? (UK)
I also read elsewhere that there was an issue with a certain year/batch of Heat Links... is this true?
Many thanks in advance
10-01-2023 08:37 AM
No lights, no power, sounds shot to me!!
Yes you can purchase another Heat Link, but not from Google, ebay is your best bet.
The story about a bad year, well that's not exactly correct, as newer Heat Links have failed for the same component.
You probably need to read more than 2 posts, and that might give you other solutions.
Silly question, but who fitted and where did you purchase the thermostat?
10-06-2023 04:16 AM
Frustratedddd - thanks for the reply - my electrician got the units new from his electrical supplier making sure they were the latest models (couple of years ago). I triust the electrician - he has fitted loads of these Nests for years...
Thanks for the info - it seems bad that there have been a lot of failures with the Heat Links...
10-06-2023 05:41 AM - edited 10-06-2023 05:43 AM
I understand where your coming from, but in Nest defence [I am NOT a Google fan believe me, read my early posts after they stole my doorbell, and never seen again] this small component failure has cost them thousands!!!
The reason I ask where you purchased, [and it's nothing to do with who you trust], but as luck has it here in the UK we have consumer law. You will be covered for more than 2 years the manufacture states. A thermostat from the installer/retailer about 5 years cover! Look up consumer if you are unaware.
Good luck.
10-02-2023 02:18 AM
Hi there @TonusBonus ! I'm really sorry to hear about this, but I'll do my best to help. Could you please respond to the following set of questions and also try the steps at the end?
Troubleshooting steps:
10-04-2023 03:27 AM
Hi, I wanted to check in. Did you see my colleague's message?
10-06-2023 02:35 AM
Just did - thank you
10-06-2023 02:35 AM
Hi TudorL, thank for getting back sorry for the delay.... to answer your questions...
1. I have a pair of Display 3.4's
2. Not seeing anything on the display as there's no power to the unit. Says 'OFFLINE' on the app.
3. No recent service to the plumbing or electrical systems.
4. I tried to press and hold the button on the Heat Link - nothing happened. I also checked the breakers here and they are all on. I'm not sure which breaker switch has the power for the Nest.
5. Not quite sure what you mean by Zones but we have one nest for the central heating (working fine) and one for then Kitchen underfloor heating (broken Heat Link)
6. No outages lately
Hope that van help! Looking forward to your reply!
10-09-2023 09:49 AM
Hi there @TonusBonus. Thanks for the answers. Would it be okay if I send you an email with a link to a form, so I can create a case for you?
10-10-2023 01:17 AM
Yeh of course, thanks - I'd really like to get this sorted as soon as possible.
10-10-2023 02:56 AM
Great, I've just managed to send you an email on the address connected to your Community account.
10-12-2023 08:28 AM
Hi there, just checking in! Did you see the message from my colleague?
10-13-2023 01:23 AM
Hi Larisa - sorry, which message are you referring to? I got an email with which to open a case, quote a number, provide an address etc. I haven't heard anything since...
Could you please advise as to when you'll be in touch again? Getting colder over here.........
10-17-2023 05:36 AM
I managed to find your case, would it be okay with you if we continue the conversation over the email?
10-17-2023 07:42 AM
Hi Larisa - thank for getting back - I just got your email and replied to it... hope that will reach you?! I'd like to proceed with your suggestion please! Many thanks
10-17-2023 07:50 AM
I replied to your email. Would there be anything else I can help you with here?
10-17-2023 09:13 AM
Got your reply - that's perfect, thanks all for your help!
10-17-2023 09:19 AM - edited 10-17-2023 09:19 AM
It was our pleasure. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community. Thanks, Larisa.
