Heatlink inoperative, no LED and H71 error
DanielK1
Heatlink inoperative, no LED and H71 error. Power going to the Heatlink and only a couple of years old.
6 REPLIES 6
AlexD
Thanks for reaching out to us @DanielK1 . I would be happy to try and assist.
If you have not already, check the breakers and switches at the location, to make sure nothing has tripped. Also check the boiler as it can sometimes have a separate switch on it. Confirm it has power, it should have a display or LED that turns on.
If it all looks good try and power cycle the Heat Link, if you're comfortable in doing so. Turn the power to the Heat Link off for a few minutes and then turn it back on. See if it has any reaction after, when you press the button on it.
george_t
HI @DanielK1. Did you manage to read the last message from my colleague?
GeorgeT
All sorted. Had a very local guy repair the wall unit. Common fault. Thanks
george_t
I'm glad to hear that @DanielK1. Is there anything else I can help you with for now?
GeorgeT
DragosC
Hi there. I'm just following up on our last message. Do you still need our help? Keep us posted.
george_t
It's been a while since this thread was last updated so I'll go ahead and lock this thread. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
GeorgeT
