Hot water icon that managed my pool heating scheduling from domestic boilere disappeared
NROSS
HI there
I use my Nest app and online login to schedule my pool heating from my domestic boiler. the hot water icon has disappeared and i cannot heat pool. I can only heat house. I've tried set up pro etc. Cant seem to get it back? HELP!
UanaC
Hello there! Thanks for posting and I'm sorry for any inconvenience this may have caused. Can you please go again to Settings -> Equipment - > Pro Setup, select System Boiler and let me know what shows next to the hot water section.
Many thanks, Oana.
AlexD
Hi, I wanted to check in. Did you check my colleagues suggestion? Let me know if you need any further assistance.
LarisaL
Hey there, I haven't heard from you in a while so I'll be locking this thread. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community. Thanks, Larisa
