Need help whit instalation
cuconio
Hi I’m trying to install my nest thermostat, but my old one only has two wires Here’s a pic. It’s a ct30A1005 date code 1723 it’s not digital. I need help whit this installation. Thanks
6 REPLIES 6
Houptee
Silver Product Expert
The wires will go to Rh and W1
But you need a extra wire for C common to give the Nest 24v AC power.
Can you pull a new Thermostat wire up the wall from the system with 5 colored wires is it visible where the old wire comes from?
And the heating system needs a C terminal on the furnace to connect the (normally use blue) wire to C.
Follow the wire back to the system and take a pic of where they connect to the heating system so we can determine if you have a way to connect a C wire.
EdwardT
@cuconio, how's it going with your Nest Thermostat? Still need our help?
Edward
cuconio
yea I finally got it to work. I installed the c wire to the system and somehow the nest thermostat keep sayin that there no power on the c wire. so I bought a 24 volt transformer and yes! worked perfect. but thanks for asking I appreciated.
EdwardT
Hi cuconio,
Thanks for the update! I'm glad to hear that you were able to get it working. Please observe it for now and let us know if anything comes up.
Edward
EdwardT
Hey cuconio,
Edward
EdwardT
Hi cuconio,
Edward
