07-16-2022 05:52 AM
How can this NOT be compatible? I just bought a condo with a heat pump. I believe it’s two stage for heat. Here’s a pic of my current Carrier Thermostat wiring. Why wouldn’t this be compatible??? I am thinking it has to do with the “W2” wire and the “W1/O/B” wire
old Y1 goes to Y
old C goes to C
old W1/O/B goes to ???
old W2 goes to ???
old G goes to G
old R goes to R
Any suggestions or help on the correct wiring would be appreciated! I didn’t check compatible first, ugh… as you can see, the Nest is mounted behind my old thermostat. I had labeled and disconnected then encountered the problem, so I re-wired my old thermostat.
Thank you in advance!
07-20-2022 01:41 PM
Hi DanaNorman,
Thanks for reaching out. I'm sorry to hear that you're having an issue with your Nest Thermostat. Since you have a heat pump, you could put the orange wire to the OB terminal and the white wire to the W terminal.
Let us know how it goes.
Edward
07-20-2022 02:42 PM
Hi- thanks for replying. I tried that wiring and it still would not work. I returned the Nest today. It’s impossible to know if it’s a wiring /compatibility issue OR if I have a defective Nest thermostat. I have installed Nest thermostats in other properties without any issue, yet those were not 2 stage heat pumps. It’s not rocket science to connect the wires. I’m going to try a different brand of smart thermostat that’s Alexa compatible. Thanks again!
07-23-2022 07:31 PM
Hi DanaNorman,
Thanks for the response. We're sad to see you go. Let us know if you have other questions and we'd be glad to assist.
Edward
07-27-2022 12:19 PM
Hey DanaNorman,
I am sorry to hear about the poor expience. With you no longer having the device for us to troubleshoot, I am going to lock the thread at this time. If you run into any questions from here, please feel free to create a new post.
