08-15-2022 08:06 AM
My nest thermostat is powered 240 volt plugged into a socket . Am I able to plug it into a USB port on my smart tv to power the nest instead of using a plug socket ? Just looking at freeing up another plug socket
08-20-2022 06:17 AM
Hi @Chewynewy. If the TV's USB port provides 5V - 1 Amp, it should be fine. But keep in mind that if you turn off the TV, it could turn off power to the thermostat. Be sure to check if your TV has the option to provide power to USB ports when turned off.
08-22-2022 06:29 AM
Hey there. Just checking in. Do you still need assistance?
08-25-2022 07:06 AM
Hi there again, did you have a chance to check the messages my colleagues sent? Let me know if you still need our help.
08-25-2022 07:36 AM
All seems to be working OK running from the USB port at the back of the TV. No issues so far . Fingers crossed . Thanks for the replies
08-25-2022 08:23 AM
@Chewynewy, that's brilliant. I'm really happy to hear this. Let's be optimistic that the things will run smoothly. Since the issue seems to be sorted, I'll be locking this thread and if by any chance you'll need our assistance in the future, please reach back and start a new one. Take care and stay safe!
