03-28-2023 07:45 AM
I've made a thread about this about a year ago but, I did not find an answer to my question.
I am getting a fairly quiet ticking sound from the nest thermostat when It is in active heating mode. My other Nest does not make this sound when in heating mode. What would be causing this problem? I have an oil furnace with constant power to the thermostat from the furnace wiring.
03-28-2023 08:29 AM
I have come across this a few times, and the cause usually is the signs of a faulty battery. I think the processor struggles, and hence the clicking noise. Are you still getting a display OK, as the display usually goes blank?
03-28-2023 09:03 AM
The same thermostat is now giving me issues of not being able to connect to wifi. Nest refuses to give me a replacement as well.
03-28-2023 09:10 AM - edited 03-28-2023 09:13 AM
That also can be an issue, as not enough power to the display. What's the voltage showing?
How old is the thermostat?
What was the outcome from last year when you posted the same issue?
03-28-2023 09:14 AM
The voltage is 3.5 V. I've tried all troubleshooting and nothing works.
This thermostat is a replacement from a previous and is 1 year old. the original thermostat purchase was just over 2 years ago now so, they are basing their replacement time off that original purchase.. Really let down by the warranty here and the product as It's otherwise great. My main floor has been going without a hitch for these close of 3 years.
03-28-2023 09:20 AM
That voltage is way to low, you need at least 3.7v
Try plugging a USB into the back for an hour, and see if that gets the battery charged better.
I assume all connections are good?
That's the trouble with a replacement, it carries on from the original purchase!
Returning back to the retailer/Installer would have been a far better way.
I'm in the UK, and the Nest warranty says 2 years, BUT here we have consumer law that covers us for retailers, and that covers for way over that period of time, 5 years +.
03-28-2023 09:22 AM
I've tried it all. I guess I'm **bleep** out of luck.
03-28-2023 09:23 AM - edited 03-28-2023 09:23 AM
May be a long shot, but have you changed the 2 displays over? That would prove the wiring is good?
03-28-2023 09:24 AM
Sure have.
03-28-2023 09:27 AM
Looks like your in the horrible stuff in that case!!
You could always try and contact Nest again, you might get an agent that's helpfull another day....
03-28-2023 09:40 AM
Thanks for all the troubleshooting efforts, Frustratedddd.
Hey Alreadyauser,
I think we need to get you to a higher tier of support on this one. I'm going to share a link to a form. If you can fill that out, one of our agents will reach out to you directly. They will also take over the troubleshooting efforts once you're in contact. Here's that link: https://goo.gle/3BICUaB.
Once you have filled that out, let me know. If you have any other questions, just let me know.
Jeff
03-28-2023 10:00 AM
Hi, Jeff. I've filled out this form as requested
03-28-2023 11:19 AM
Thanks for getting to that so quickly, Alreadyauser.
Keep an eye on the email you used to register for the forums. You will see a response there from one of our internal support agents and they will take over the troubleshooting process from there. Again, if you have any questions in the meantime, I'll be happy to help as much as possible.
Jeff
03-31-2023 11:26 AM
I wanted to check in, and make sure you are in contact with our team. Please let me know if you have any trouble seeing the email, as I want to ensure you are being helped.
03-31-2023 04:12 PM
I have not received an email
04-20-2023 11:47 AM
Hello Alreadyauser,
I'm sorry if it takes longer than usual. Our internal team will get back to you as soon as they can. In the meantime, if you come across other information you'd like to pass along or have further questions, feel free to reply to this thread.
Thanks for the help here, Jake and Jeff.
03-27-2023 06:34 PM
My Thermostat had a low battery for and unknown reason and will not connect to my WIFI network. I've done all the trouble shooting given and still nothing. I'm looking to maybe speak to someone about my issues. At this point I have deleted it from my app and am trying to add it back with no luck.
03-27-2023 08:07 PM
Alreadyauser,
the Nest thermostat loves to have a power common wire. When the Nest relies on the batteries, and the batteries become weak, the nest starts disabling WiFi and other features to preserve energy to still be able turn on the heat or cooling.
The AC Cooling Wizard
03-28-2023 02:30 AM
Thanks for your reply, but I'm confident that this is not the problem. I have another Nest Learning Thermo downstairs and have never had a problem with it. I've had that one for 3 years and this other I've already had to replace. The wirings the same and for the same furnace.
04-10-2023 06:13 PM
It cannot be that both thermostats are wired to the exact same furnace, because that would be an invalid configuration and would not work. If this is the case, and what you have is possibly a zone controller, and the thermostats should be wired to the zone controller.
04-12-2023 08:14 AM
Yes. I have three zones, controlled independently by three thermostats, on three separate floors, all connected to the same furnace.
04-15-2023 12:56 PM
Hi Alreadyauser,
I'll merge this thread with the main post, where all the updates will be posted, so we can communicate effectively. You can follow the main thread for news because this one will be locked automatically once merged.
04-03-2023 04:11 AM
I appreciate your response, but I've already done all the simple "turn it off and on, blow in it" type trouble shooting.
04-08-2023 07:52 AM
Thanks for posting here in Community and I'm sorry to hear about the situation. Can you help me with your Nest Learning Thermostat's power reading?
Thanks for lending a help, @CoolingWizard and @Dianahemes.
04-08-2023 03:01 PM
Voc - 34.34 v
Vin - 31.99 v
Lin - 20 mA (i)
