12-11-2022 05:40 PM
I have a Trane Heat pump with aux propane heat. Trying to install Nest thermostat. It’s telling me it’s incompatible when I enter my wiring details. Sharing a pic. Just want to confirm I haven’t entered something wrong before sending back? Thanks in advance
12-16-2022 05:09 PM
Hi TNRazorbacker,
Thanks for reaching out and sharing the photo of your current thermostat's wiring. It looks like this would work with a Nest Learning Thermostat but I want to make sure. Could you share the make and model of your current thermostat?
Edward
12-17-2022 08:52 AM
Thanks for responding. Pic attached below- I have two I’d like to install - both shown. The one on top is wiring I’d posted previously.
12-19-2022 06:32 PM
Hi TNRazorbacker,
Thanks for sharing the model of your current thermostat. The OT1 and OT2 wires are for the outdoor temp. You don't need to wire these 2 on your Nest Thermostat as it get its outdoor temperature information from the internet.
Edward
12-22-2022 06:39 PM
Hi TNRazorbacker,
Edward
12-26-2022 02:55 PM
Hi TNRazorbacker,
Edward
12-27-2022 05:24 AM
Both my units are heat pumps with auxiliary heat that kicks on when the temp drops below a set temp. Is there anything I need to do from a settings standpoint to make sure this works properly? Thanks for the help
12-27-2022 04:00 PM
So I have a Nest Learning thermostat and when I put my wires in during the installation process it tells me a pro installer is required? I don’t really want to pay for that. Is that truly needed based on my wiring?
12-28-2022 03:45 PM
Hi TNRazorbacker,
Thanks for the response. We'd like to know more about this. Please fill out this form so we could investigate further.
Edward
01-02-2023 10:01 AM
TNRazorbacker, checking back in — have you had the chance to fill out the form?
Mel
01-05-2023 11:13 AM
Hi TNRazorbacker,
I wanted to follow up and see if you are still in need of any help. If so, please fill out the form so we can help you further.
Mel
01-09-2023 10:37 AM
Hi TNRazorbacker,
I'm just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this thread after 24 hours.
Mel
