Connecting Google Wifi wirelessly to Bell Fibe Home Hub 4000
martinomac
I've got a few dead zones in my home with 3 Google Wifi points:
- 1 Google Wifi router connected to home hub 3000, other 2 Google wifi points throughout the house but lack connection on the far end.
- I do not want to purchase another Google Wifi point.
- I would like to know if when my new home hub 4000 arrives if I could connect my Google wifi to it wirelessly, that way I can use the 3 pods in better locations throughout the house?
thanks,
Martin
David_K
Normally no, the software should update by itself
6 REPLIES 6
David_K
No unfortunately. Your primary Wifi point's WAN port must have a wired connection to your router/modem.
martinomac
OK thank you for clarifying.  I recently had a Google Wifi technician diagnose my 3 mesh system and noticed it was on old firmware.  We did a factory reset and it then updated software during initialization but it involved adding all 3 points all over again.
Moving forward, will firmware updates require factory resets?
Jeff
Hi martinomac,
It looks like davidking was able to find an answer for you on this. Before I mark the thread as resolved, I wanted to check in and see if there's anything else you might need.
Jeff
EdwardT
Edward
EdwardT
Edward
David_K
