issues setting up 2nd wifi point.
jamiehurt
I had no issues setting up the first point with the ethernet cable connecting it to the modem.  When I go through the setup for the 2nd point it gets to the step where it asks if you want to connect to a network and instead of connecting to the network I set up it tries connecting to the default network listed on the bottom of that wifi point.  That network has no connection so it obviously fails.  How do I correct the issue and have it try to connect to the network I set up on the first wifi point?
olavrb
Make sure you have no VPN enabled/ connected, not any 3rd party product, nor the "Apple iCloud Private Relay".
https://support.apple.com/en-us/HT212614
Make sure the Google Home app has permissions to "local network access".
https://support.google.com/chromecast/answer/7172427?hl=en&co=GENIE.Platform%3DiOS
Then, it should work. If not, try the Google Home app from a different Android or iOS device, using the same Google account.
I don't work for Google.
olavrb
EdwardT
@olavrb, thanks for the help!
@jamiehurt, how's it going with your Google Wifi? Were you able to check the link provided by olavrb? Keep us posted.
Edward
EdwardT
Hi jamiehurt,
Edward
EdwardT
Hi jamiehurt,
Edward
