Montaje del next Yale lock
Carlos52
Cómo hacer que la cerradura Nest x yale cambie el sentido  para usar en una puerta a la izquierda
David_K
Nest x Yale Lock automatically determines whether it will function as a right or left-handed lock. The "hand" or "handing" of the lock, is determined by the side of the door that the hinges are on when standing outside the door. When the batteries are properly inserted for the first time, the lock will attempt to determine its handing, whether the lock is installed on the door or not. If the lock is not completely installed on the door when the batteries are inserted, it could hand itself incorrectly. Should this occur, the lock must be installed on the door and then reset to its factory defaults, allowing the lock to "hand" itself correctly.
To reset the lock:
Factory reset the Nest × Yale Lock - Google Nest Help
During setup, be sure to install the lock first and test it works with the door open and closed. Then keep the door closed and unlocked while you install the batteries. If the door is locked, your lock might not test and calibrate itself to your door properly.
Nest × Yale Lock installation and setup - Google Nest Help
Hope this helps!
David_K
To reset the lock:
Hope this helps!
Juni
Thanks for the help, davidking.
Carlos52, thanks for reaching out. I hope you've got the answer you're looking for. If you're still in need of assistance, please let us know, as we would be happy to answer any questions you may have.
Juni
Hello there,
Thanks for your assistance here, Juni.
@Carlos52, I wanted to see if you still needed help. Please let us know if you have any other questions or concerns.
zoeuvre
Hi Carlos52,
We haven't heard from you in a while, so we'll be locking this thread if there is no update within 24 hours. If you run into any more issues in the future, please feel free to create a new thread.
All the best,
