02-16-2022 02:26 PM
When my Nest Connect is unplugged, it blinks yellow and does not connect to my Yale lock. It also doesn't connect to the lock when it is plugged in.
Process is:
1) while it's plugged in, it is solid green,
2) the lock was not working, so I went through the troubleshooting process outlined in the app,
3) per the instructions, I unplugged the Connect and pressed the button,
4) it flashed blue once,
5) it turned green for about 1 second then turned off,
6) it flashes yellow from then on.
This yellow flashing is not in the troubleshooting instructions as an option. What does it mean, and what do I do?
03-18-2022 09:33 PM
I’ve the same issue with my nest connect. It’d be great if there’s anyone out there to assist fixing this problem.
03-21-2022 09:28 AM
03-21-2022 06:48 PM
Yes, Brad. I still need help. If you could help out, that would be wonderful.
-Mark
03-22-2022 08:16 AM
I am sorry to hear that you are still having this same issue! I would suggest Restarting the devices first, and if that doesn't work then you try to Factory Reset the device. Both of them could assist you in this issue.
05-03-2022 11:42 PM
Chiming in to check if you have additional questions or concerns as we will be locking this thread within 24 hours.
Let us know so we can assist you right away.
Archie
05-05-2022 09:49 PM
You might want to check out this link. If the issue persists, feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
Archie
