Nest/Yale lock issues
Chip333
I have the nest yale lock. It worked fine for a month but now more time than not I get an alert via the app saying the deadbolt is unable to lock. I’ve stood there while it auto locks and see the deadbolt extend into the door jamb as it should and I still get the warning. The batteries are brand new and the wifi connection is strong. There are no physical obstructions. My other lock works fine but not sure what to do with this one. Any suggestions on resetting or something?!? Thanks in advance.
6 REPLIES 6
5kevents
I have started having this issue - can not correct it
@bgb1122
I'm sorry to hear that you're experiencing the same issue! Have you tried to Factory Reset your device? I would give that a go if you haven't already. Please let me know if you need further assistance.
Bradl.
Just checking in to see if you still need assistance with this issue.  We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
Hey Folks.
