Nest Yale on 3” Thick Door
LQ
How can I install Nest x Yale on a 3” Thick Door?
janthadeus
Hi LQ,
Thanks for reaching out. It would help a lot if you could share a photo of your door so we can have a better look. Have a look at this guide: Nest × Yale Lock installation and setup.
LQ
 this is the door, 3” thick
janthadeus
Thanks for sharing the photo with us. Your door is too thick to install your Nest x Yale Lock. Your door’s thickness should be one of the following:
  • 1 ⅜ inches
  • 1 ¾ inches
  • 2 to 2 ¼ inches
The lock hole center is either 2 ⅜ or 2 ¾ inches from the edge of the door.
You may contact our installation partner, OnTech, to help you check your system’s compatibility, install, and set up your Nest products.
janthadeus
I just wanted to jump in here to make sure that you saw my response. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
janthadeus
Hey LQ,
How's it going with your Nest x Yale Lock? Still need our help?
