Power Outage
TY13RS
Every time we have a power outage that lasts longer than an hour, our Nest Connect and Nest x Yale lock does not want to reconnect until I factory reboot both. It's really inconvenient to have to do this EVERY time. Is there a way to make sure they both reconnect automatically when power is restored and is anyone else having the same issues?
If you are having issues with your Nest Cam or Nest Doorbell, I would suggest that you first start by restarting it.
Restart: Keeps all your settings, and it should reconnect to the same Wi-Fi network. This is helpful if it ever becomes frozen, has trouble reconnecting to the internet, or isn't working normally.
Best regard,
TY13RS
This issue is with the Nest X Yale door lock. And restarting it is not my issue. My issue is when my home has a POWER OUTAGE, I have to factory reset my Nest hub and my door lock to get them to reconnect to eachother and the app.
  • Open the Google Home app
Google Home app
  • At the top right, tap your account.
  • Tap Feedback
and then
  • tap the type of device you'd like to submit feedback for.
  • To display available emails, in the "From:" section, tap the arrow on the right. Select your email address.
  • In the feedback summary, write a brief description of your issue.
  • Be sure to check the box for Screenshot and System logs.
  • To submit feedback, at the top right corner, tap Send
If you need anything else, please let me know.
Just checking in on this thread and the activity on it. We'll leave this topic open for another 24 hours in case there are any follow up questions or comments.
