Pushing Yale button automatically unlocks door (no code inputted)
AmericanIMG
I can lock the door using my passcode but pushing the Yale button automatically unlocks the door. I'm not using the app at all
aliasrocks
I think you have installed backwards
AmericanIMG
How do I fix that?
No something I can type without seeing the lock mechanism.
what you described is the opposite action is occurring if I understood correct. So putting in the code should rotate mechanism to pull back dead bolt. The Yale logo rotates to lock. So you need to put the mechanism in the door to rotate correctly
Lance_L
Hi AmericanIMG,
Thanks for posting in our Community. I’m sorry for the delayed response here and to hear that you’re having issues with the Nest x Yale lock. No worries; I’m here to help. Let’s check it out.
To fix the lock mechanism issue, you’ll need to factory reset the lock, remove it from the Nest app, and add it back to the account. Follow the steps below:
  1. Factory reset the Nest × Yale Lock.
  2. To remove the lock from your account, on the Nest app home screen, select your lock > tap Settings  > Remove lock.
  3. Connect your lock to the Nest app.
Let me know how it goes.
I appreciate your help, aliasrocks.
Lance
Lance_L
Hello AmericanIMG,
I wanted to follow up and see if you are still in need of any help. Have you had the chance to try the suggestion above? If yes, how is it?
Lance
