GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,124 REPLIES 16,124
jjkilpatrick
How can I reconnect the device to WiFi without completing a factory reset? My device will not connect to WiFi since the issue was identified. I've tried unplugging the device to reset the device.
You have to trick the software.
Just reset the date to pre the 9th of march on your phone/tablet. Start the installation proces. Reconnect to your wifi. And your Chromecast is back on line. For me it worked fine. Good luck.
Don't forget to reset the date to present day.
Panda30
Wait! I turned off my wifi, changed the date manually to March 7, turned Wi-Fi on. Set up Chromecast and still not working. What did I miss?
RJ12
Now you have to wait for the fix/update from Google. Which is automatically going to be uploaded. Because now your Chromecast is connected to your Wi-fi again. I live in the Netherlands and I recieved the update/fix yesterday, march the 13th. Have a great day. 🙏
Thank you for your help.
I tried changing the date on my phone but it's not prompting me to set up the device and connect to WiFi. Any other suggestions? I haven't completed a factory reset.
YaelOlvera
Ya restablecí el Chromecast a configuración de fábrica quedo en espera actualizaciones para arreglar el problema
Anonymous
Not applicable
What about for those of us who assumed you had broken their current Chromecast and had already bought a new Google TV streamer to replace it? Will there be any compensation? I had an event where I needed Chromecast functionality so I had to pay for the streamer as my old one was broken. That's money I'd rather have not spent.
elitorres
Yo sin saber, por qué no fui notificada a tiempo lo reinicie y ahora cuánto más tengo que seguir esperando para solucionar? 13/3/25
Efily
Pra quem redefiniu, mude a data do celular 08/03 que volta ao menos como era, e espera eles consertarem
Mannu
Cambia la fecha de tu teléfono para el 08/03 e haces de vuelta la conexión en Google home. Yo recién. Lo hice y me resultó
JJJ12
Lo hice y funcionó!!!
DrRox
Thanks for the update. Please be aware that this has caused significant issues to our business and home setup. we have 12 chromecast audio devices streaming to different rooms. We now have no audio available. Please fix asap.
Pablito_82
Si estoy teniendo problemas para utenticar el chromecast quedo a la espera de que me indiquéis como solucionarlo. Gracias
raianedarc
Estou com esse problema aí, só que eu redefini o aparelho, preciso de ajuda o quanto antes! Estamos sem acesso a tv por conta disso. 😩
xyloguy
Pretty slow to find a resolution... Do you even have a work around?
Anonymous
Not applicable
Mirate este video funciona https://youtu.be/2EfKL8Qc8Sk?feature=shared
pichicuita
Ahora que avisaron, entiendo el por qué de qué se prende y apaga.
BATMAN37
I did a factory reset not knowing I was supposed to. What do I do now?
KuriosV
For all the factory reset people who are freaking out and asking "what do I do now?":
1) Temporarily set the date on your smartphone (or tablet) to March 8 or earlier.
2) Use the Google Home app to re-setup your Chromecast. You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Also, you can change your phone's date/time setting back to Auto now.
3) Sit back and wait for the firmware update from Google to be installed.
Supposedly it's going to be a phased rollout, so it could take as long as several days for the firmware update to hit your device. Patience.
**Google really should pin this information to the top of this page.**
Thanks for copying and pasting my post. Dude literally asked "What do I do now?", like half the people here. 🙂
Qlinick
Why does this take so long Guys ?? Its your product ?
Juliana2
Aguardando solução
Gasparalves
Não conecta com a tv
rhoelz
I reset my device. What have I do now?
 ok Johnny did like you said,  backdated on iPhone it does show the chrome cast symbol says the name where it should etc. but still comes up as above. So I guess it’s still needs the update right?
Aleparedes
Apurense
SaamiXD
The message about NOT FACTORY RESTING came a little too late… any new updates on fixing the issue?
ShivamKumar7206
Jefferazzi
Factory reset is one of the troubleshooting steps here . This is what I did... now I've been without my Chromecast for several days 😩
Morena25
Meu deus prq não volta a funcionar
gabrieloui
Do you really think there could be someone who didn't reset?
Then you are really crazy 😂
JuliiAlvarez
I've already reset it, please I need help I don't want to lose my device!!
