GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,144 REPLIES 16,144
MaHaHo
Yes, under general setting go to date and time and switch from automatic.
then you can set the date.
Worked for me !
Vamos! Why didn't Google inform about this fix right away...well I'm glad you did 👍🏼
Thank you so much! You are a legend!
i exactly did this and it works great for me. from Pakistan
GoogleNestTeam
Aqui voltou, funcionando perfeitamente
Brasil
Aqui não como vc fez?
Lo reinicie el lunes y no me anda 🤦🏼‍♀️
Cambia la fecha de tu teléfono posterior al 07/03 lego configura el el dispositivo y se actualiza
JJTC09
Hice lo de la fecha y funciono
Anonymous
Not applicable
Está ok !! Valeu
Msouza
Funcionou perfeitamente...
Muito obrigado!
COMO HACES PARA CAMBIAR Y CORREGIR TODO. POR FAVOR ME PODES INDICAR BIEN.
MUCHAS GRACIAS
Vc fez reset quando parou de funcionar? Eu fiz e ainda não voltou aqui.
Deu sorte. O meu continua fora.
Anonymous
Not applicable
The Google troubleshoot site still recommends a factory reset...
So unbelievably annoying that I've trusted the Google support docs
Yo tambien
Change your date in your phone to before the issue began. It allows you to update. Once back updated you can change your date back to todays date
This one worked! Chromecast has been able to connect and update after being connected with wifi. Thanks!
Perfecto ya he llegado la actualización al Chromecast (2.ª generación): Versión de firmware 1.56.467165
Seems to work if you set the date to 3/7/25, setup device and return date to today... this is if you factory reset you device....
ignorp
Change date on your phone, setup from Google Home add Device and reset date on phone...
BRIVES
A future date??
No! 2 days before the error.
Wilsonc86
I changed mine on my phone to two weeks ago it updated the chrome cast and then changed the date back to todays date
It’s worked!!!! Thank you so much! You’re an angel! ❤️❤️❤️
Nanna920
Where do I change the date?
rgaagun
You have to change the date  in your Phone to 8 march for example. Then configure your chromecast again and let it in wifi status and wait for  Google update.
Per57
How do i change date in my phone
Pranv
In the phone settings
Como fazer isso manda o passo a passo por favor
Troca a data do seu telefone para o dia 7 de março (data que o aparelho estava funcionando). Vá nas configurações do seu celular. Feito isso faça a conexão do Chromecast normalmente. Ele vai atualizar automaticamente. Depois disso vc troca pra data atual.
Me sirvió, muchísimas gracias 👌🏻.
Divya77
I did still its not working what to do
Afrancol
Great, that worked perfectly. Thank you from Italy
thank you to the team that worked to make chromecast functional. I mention that the device came to life again and works. I mention that I accidentally reset the device but I solved it with the method of changing the date back to 08.03.2025 so I managed to reinstall it, and now it works. thanks once again to those who were involved in solving the problem
Diana5
Mine is still not working 😕! I don't know how to change the date
ignorp
Anonymous
Not applicable
What device are you using to view streaming app?
Bonjour
6 jours et toujours pas de solution pour ceux qui ont suivi la page d'aide disant de réinitialiser...Les félicitations s'imposent !
