GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,162 REPLIES 16,162
I am having the same problem! I had no problems earlier today.
New INFO in Pinned Post from Google:  Regarding an issue with Chromecast 2nd gen and Chr... - Google Nest Community
(I will mark this as "answer" only to get visibility in the large volume of posts)
Kenay
No se puede autenticar el Chromecast
Desde el día de ayer el dispositivo estaba sin reconocer para transmitir, lo reinicié y se me borró de la aplicación de Home y ahora intento configurarla nuevamente el dispositivo y me dice que no se puede autenticar el Chromecast
Victoringo
Me pasa lo mismo y no encuentro la solucion
Tarteaga
Me pasó lo mismo. Ya Google avisó que está trabajando en la solución. Al parecer venció el certificado original, que tenía por 10 años y deben renovarlo. Ojalá lo.areglen pronto!!!
Fra66
Da ieri sera Chromecast non si collega più e non di riesce più a configurare,home trova il dispositivo ma non riesce ad autenticarlo.
Mahendarsb
Hi, since yesterday we and many more global user facing following issue as they are unabke to connect sync cast mobile deive to chrome cast connected device.
TV couldn't be varified. This could be caused by outdated firmware
Kind help us as our TV is not smart TV wothout chrome cast TV is not usable for us.
Yes, me too
So I have this issue.
my chromecast has worked fine for many years, yesterday i could bot connect - so I choose to reset my chromecast. But when I try to connect to the wifi, it says that i have to give access to my local network, it gives the option to go directly to the place in iphone settings where you can s itch it on and off. I have switch all access option on “bluetooth, local network even camera” but i can’t get past this point.
It also says i cant communicate with my device “iphone” .. I have tried to turn my phone off and the wifi off… but nothing seems to work. Please help me
I have the same situation since today. Tried everything: updated Google Home app, reboot Chronecast 2, turned off and reopen the IPhone, reboot the wi-if extender. Nothing worked. It just does not connect to wi-fi.
Hope that someone will come to a solution, I am totally helpless….
Anonymous
Not applicable
Hi, same problem for me
any solution ?
Lmmm
Unfortunately  the whole world is waiting for Google to fix this problem......
boomjam
My 2nd Gen suddenly disconnected from the router and I haven't been able to figure out how to re connect.
Router SSID Has not changed and has also been rebooted.  Chromecast has been factory reset a couple of times.
Tried via Google Home app on iPhone and it got to the connect to wifi screen before the chrome cast would be stuck on "connecting" and then iphone will say "something went wrong"
When tried with ipad google home app, chromecast would show the 4 digit pin but the ipad wouldn't even show that.
Chromecast's SSID is broadcasting, not sure what other steps i could take here
Alex34700
Bonjour
Depuis hier je n arrive plus à connecter mon chromcast sur mon téléphone.
J ai tout débranché, rebranché ...rien y fait .
M-ali
Chromecast is not connecting.  Authentication error.  Any solution ,?
So Thats a GLOBAL Problem Started From Yesterday, As Today No solution, but google is trying to fix it👍🏻
Hello, so yesterday i went to use my chromecast and watch a Video on youtube, I saw that my Youtube Chromecast couldnt work and said its "not verrified", i thought its a random bug i went to reset it and it said "we coudlnt authenicate your chromecast", then i asked google it said Factory Reset it , it maybe works, so now i saw that they say not to factory reset, Does That Mean My device wont get fixed?
Ho lo stesso problema
As I, many people did a factory reset. It's a normal logical procedure.
Google knows this and will come with a procedure for this.
If you don't want to wait for that, yo might try what I did;
I set the time on my android mobile to an earlier date. Then I installed, with google home, the chromecast. That worked. BUT... it won't change the cerificate problem, the main issue, and we won't be able to cast. Hope, I could help you a bit with this answer.
Thanks man, i was worried that i couldnt use my chromecast anymore♥️
what announcement ?
People online say that google said to Not Factory reset
Munmun
It would have been helpful if you have announced this earlier or at least made the issue known to your customer service.
Cam9
Bonjour,
C'est un peu tard lorsqu'ils préconisent de ne pas réinitialiser le Chromecast aux paramètres d'usine... (J'ai eu la même réponse dans un mail daté d'il y a 2 heures)
Communication un peu défaillante quand même, beaucoup trop tardive 😞
Qu'adviendra-t-il pour tous les Chromecast réinitialisés? Nous devrons les mettre à la poubelle?
Wait and see comme dirait l'autre mais bon.
Perso, je suis allée m'acheter un Fire stick Xiaomi 🙂
earlbr51
Spent hours trying solutions. Tried other chromecast, changed hdmi ports, factory resets, reset router... nothing! Deprived of TV for the night. Horrors! Not sure how the fix will be communicated. Any information?
WillIV
Nothing yet. Google support posted in here earlier that they were working on it. Luckily I have an ultra that wasn't affected so wasn't totally down. If I see anything I'll post back in here. Trying to keep an eye on Reddit and Google blogs to see who makes an announcement first
StanJones
Contacted Google. They pushed a new firmware yesterday and admitted they had this problem globally. They are working to fix the issue.
Raf0
Kanno risposto troppo tardi. Molti hanno già ripristinato il dispositivo perché consigliato nelle risoluzioni dei problemi.  E ora chi ,come me ha ripristinato il dispositivo che fa?
Metti indietro la data del telefono (es. 8 marzo) con l'impostazione manuale. Stacca la rete dati ad evitare aggiornamenti automatici.
Riuscirai a rimettere nella tua rete wifi di casa il CC. Sarà comunque inutilizzabile per i problemi di casting ma almeno è online tante volte servisse per eventuali fix del problema.
Nadders22
Yes I’ve had same phone, same TV, same internet and same chrome cast for past 4 years. Now suddenly Google Home can’t connect the device to my iphone. It stinks that no announcement was made or notice given that the my chromecast Gen 2 is now obsolete. I knew they were discontinuing chromecast but this is fresh BS!
Valcam
Hi from Italy.
Same problem here since sunday
I done reset to factory data and then reconnected the Chomecast by setting phone date before march 8, but, as known, doesn't work yet.
Wait for Google solution
Alicep
I think the problem will be solved by buying an Amazon stick!
andregyn29
Mesma situação com meu dispositivo Chrome cast geração 2
epdavidg46
Fix this fast basketball is soon!
Fix it fast!
Hi @matthieubrucher and all,
I will escalate this to our Chromecast team.
In the meantime please try to restart or reset your Chromecasts.How to factory reset your Chromecast or Google TV Streamer - Android - Streaming Help
Can you let us know the device you are using, your region and the Cast firmware version. (Device info, Tech info)
Thanks!
Sandy28
Quando será solucionado?
Carstenk
Have tried that of course.
Firmware version? No idea. On the screen saying 0625. Another time it was 3574. Same Chromecast
Hi there. It's a gen 2 chromecast
Technische Informationen
Version der Systemfirmware: 275994
Cast-Firmware: 1.56.275994
And several chromecast audios were I can't get to the version information any more.
Bobsy
Have reset router, phone, and Chromecast and still getting the issue.
