GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Hurry up, it's starting to get annoying pleas!
Still not fixed a week later, very disappointing google!!
My Google Chrome cast 2nd generation flashing msz that the firmware is outdated
so please if Google admin confirm when this problem will get resolved now it's more than a week now.
Please answer!!
Is there another update re the audio fix? It's been 5 days....can cast but no audio
Any further update to this??
Any news for us who has done a factory reset during initial troubleshooting?
joelios
If you resetted it like I did, just change your phone's date to March 8th or earlier and start the process of setting up your Chromecast from the Google Home app. Unfortunately, this still doesn't fix the casting issue, but it does leave you on the Chromecast wallpaper screen so it can receive the update.
What is going on with the Factory Reset fix?
fml848919
reset the date on your google home device to march 7. then you'll be able to reconnect.
もぅデバイスをリセットしてしまいました。
Is there a fix yet for us loser's who did a factory reset??
joelios
If you resetted it like I did, just change your phone's date to March 7th or earlier and start the process of setting up your Chromecast from the Google Home app. Unfortunately, this still doesn't fix the casting issue, but it does leave you on the Chromecast wallpaper screen so it can receive the update.
FIX AFTER FACTORY RESET!!
Able to connect and update Chromecast after factory reset! This worked for me using iPhone;
Set date manually: Setting > general > Date & time, untick set automatically and change date to 7th March.
Using Google Home app connect Chromecast as a new device. This will prompt an update to the Chromecast.
Once updated, go back to Date & time settings and tick set automatically.
Happy streaming 🙂
Mel36
Yay it worked! Thanks so much 💃
Would appreciate an update on when the fix is done. Please supply an approximation if nothing else.
Any news on the factory reset update? I have no tv!?
Bonjour, suite à votre correctif ma Chromecast à bien redémarré et tout à fonctionné jusqu'à ce matin. Ce matin plus tien, Chromecast déconnectée et impossible de la reconnecter 🤬🤬🤬
Any news for resolving if we have made a factory reset?
joelios
Thanks
please do it asap
@GoogleNestTeamprovide more details about how you resolved the issue, whether this will recur and by when. Due to numerous failures, e.g. your first Pixel table randomly locking up - failing to recognize my PIN (requiring hard reset) -, your Nest Camera failing to comply with Home/Away rules, and now negligently failing to update the required certificate(s) prior to their expiration,  I am losing trust in your hardware.
Questi giorni sono passati già dieci giorni quando una risposta? E le istruzioni per il ripristino Grazie attendo la risposta celermente saluti
Max
Still waiting for this to be rectified, is there an ETA
See my reply above you
I changed the Watch to March 1st, and voila the Chromcast updated and worked again! Earlier I did a factory reset.
How do I change the Watch? Om tje Phone-or
Hola, me aparece este mensaje cuando trato de configurarlo:
Puede que se haya configurado Comedor, pero no hemos podido comunicarnos con el dispositivo desde tu iPhone. Comprueba que hayas habilitado el acceso a la red local en los ajustes de privacidad de tu iPhone. Luego, vuelve a intentarlo.
Voy a las configuraciones y me aparece que sí que está activado. Cómo puedo solucionarlo?
Chenje
Este es exactamente mi problema, el acceso a la red local está habilitado
Google should compensate consumers for your mistakes.
Ciao, vorrei novità o tempistiche per la risoluzione del problema, la mia chromecast ancora non si riesce ad usare dopo il ripristino e sono passati già molti giorni.
Grazie
Imposta il telefono con data al 1 marzo 2025 (metti modalità aereo per sicurezza) e procedi con l'update. Io l'ho fatto ora e funziona
Sullo smartphone ho impostato la data del 1 marzo 2025 e tramite l'APP Google Home sono riuscito a ripristinare il tutto. Grazie a tutti voi per i consigli
Hi Regarding factory reset during initial troubleshooting. What is the timeplan for this fixa and availible for the user with Chromecast (2nd gen) and  setup instruction ?
Yo resetee de fabrica como hago ahora?
Tengo generacion 2
Any news on the fix for those of us who were told to factory reset when the outtage initially happened? and now find out we are not supposed to factory reset?
joelios
If you resetted it, just change your phone's date to March 8th or earlier and start the process of setting up your Chromecast from the Google Home app. Unfortunately, this still doesn't fix the casting issue, but it does leave you on the Chromecast wallpaper screen so it can receive the update.
Thanks
bonjour,
Merci pour la mise a jour, cela fonctionne parfaitement.
Ps: pour ceux qui auraient reset usine leur chromecast, antidater votre téléphone à une date avant le 9 mars en oubliant pas de décocher la mise a jour de la date automatique sur le smartphone, vous pourrez configurer votre chrome cast pour le connecter au wifi, ensuite laisser faire la mise a jour et remettez votre téléphone au réglages d'origine.😁
