Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-16-2025 11:12 AM
necesito una solución ya
03-16-2025 11:12 AM
Buenas tardes, cuando dejo de funcionar restablecí a la configuración de fábrica dado que eran los pasos que me indicaba la app, me gustaría saber cuáles son los pasos que debo seguir ahora para hacer que vuelva a funcionar.
Gracias de antemano.
03-16-2025 11:15 AM
HO RISOLTO anche se avevo fatto il reset:
1) cambiate la data (5 marzo)
2) reimpostare il chromecast
Una volta salvato non funzionerà ma mettete la data di oggi e FUNZIONA!!
03-16-2025 11:16 AM
Solution if you reset your device.
Set your phone date back before 7 mar 2025.
Open the Home app and configure the Chromecast.
The Chromecast will connect to wifi and update.
Set your phone date to auto again.
Test if it works, if not, then give it more time to update and try again.
03-16-2025 11:16 AM - edited 03-16-2025 11:17 AM
Hello, I have a Google Chromecast and it started not working, so we tried a lot of things and finally restored it to factory reset. We didnt knew about the information you wroted on thursday, we want to fix it or if it still not working, have a solution for your negligence.
03-16-2025 11:18 AM
Mine is working again and I was one who factory reset, so I'm just here to let others know who are in the position I was in: do the trick others have mentioned of setting your phone clock back to be able to at least get it back online. It won't work for streaming with your phone clock set incorrectly, though. The other services like Hulu and YouTube won't work with an incorrect clock. So after connecting, set your phone back to normal. I just let the Chromecast stay connected to wifi and within a day Google has pushed the fix out to my device. Works as well as it always did now.
03-16-2025 11:20 AM
Thx, a lot. It also worked for me.
Set the date to March 5, and then you can setup the chromecast.
03-16-2025 11:20 AM
It doesn’t work I did the change of dates and resetting with update, my chromcast still doesn’t work
03-16-2025 11:25 AM
Bonjour,
Quand le problème sera résolu ?!!!
merci
03-16-2025 11:27 AM
Avez vous une solution ? Que faire j’ai besoin de mon appareil !
03-16-2025 02:40 AM
Hello, my chromecast is still not working, is this normal?
03-16-2025 02:50 AM
03-16-2025 04:03 AM
Just fixed now. I did factory reset and did't work without possibilty to teconfigure it.
I force date on the smartphone to first of march, after that I was able to reconfigure it with app home. Now (after the update) is still working fine.
03-16-2025 02:06 AM
Hi, for some resons, i reset from factory my chromecat 2nd generation and now i can't configurate again. It's says " autentification problem" please hepl me to get my device recover. Tnk you
03-16-2025 02:50 AM
Take a look at this buddy: https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
03-16-2025 01:05 AM
Everytime that I try to connect my Chromecast 2 Gen with Google home it Appears " your Chromecast could not be authenticated, visit mobile app for support "
Or maybe because it's to old? I have been with it for 8 years
Maybe it's fair
03-16-2025 01:34 AM
Your Chromecast 2nd Gen is quite old (released in 2015), but it should still work as Google hasn't officially discontinued support for it yet. However, the "could not be authenticated" error might be due to several reasons:
Outdated Firmware
Wi-Fi Compatibility Issues
Google Home App Issues
Device Authentication Failure
Network Firewall or Security Settings
Check Google’s Support for Older Devices
If you’ve tried everything and it still doesn’t work, 8 years is a long time for a tech device. You might want to upgrade to a Chromecast with Google TV, which has better performance and long-term support.
03-16-2025 05:51 PM
Try another method.
Just change your smart phone/iphone/tab date to 1st March 2025 and then connect chromecast..after connecting to Chromecast it will load an update for Chromecast and will connect to your wifi then you will be able to watch anything you want.i tried on my side and its working for me.
03-16-2025 01:49 AM - edited 03-16-2025 01:51 AM
I fixed the same problem for my Gen 1 device with the following steps. Since the authentication depends on certificates, I thought that it was because of the certificate signing date causing authentication issues.
1. Factory reset to the chromecast
2. Install Google Home on any mobile device.
3. Set the date of the mobile device (the one you installed the Google Home app) before March 7 (My device stopped working on that day). The date may depend on your device's manufacturing date. So I recommend setting the date at least 1 year before.
4. Proceed with setup instructions from the Google Home app. Fingers crossed. 🤞🏻
5. After you successfully set up the device, and establish the connection. You can revert back your mobile device date.
03-16-2025 02:51 AM
03-16-2025 05:08 PM
Look for johnnyzero2. Hi reply has a link on how to do it. Good luck.
03-16-2025 05:50 PM
Try another method.
03-15-2025 06:42 PM
03-15-2025 06:47 PM
Mine too!
03-15-2025 07:42 PM
Google is a JOKE! Will soon be INSOLVENT! I am beyond disappointed with them!
03-16-2025 11:29 AM
Eu resetei no mesmo dia que deu o problema e ate agora nada de resolver, tem previsão?
03-15-2025 09:30 PM
Chromecast 2 が数日前から機能しなくなり、Chromeが推奨している様に、トラブル発生時の対応としてChromecastをリセットしましたが未だ繋がらない状態です。何かの情報を求めてこちらを見つけましたがリセットしない様にあり大変困っています。新しいデバイスは高額で今直ぐに購入は出来ず間に合わせに他社製品のミラーリングのみの格安トングルを購入しましたが使用中はスマホ操作出来ないので私の用途に合わず無駄遣いしてしまいました。
リセットしてしまった人はもうChromecastを使えませんか?サポート修了された訳はないのでトラブル時推奨のリセットで使用出来なくなる事はないですよね?もしそうであれば問題前の告知がありますよね?解る方いますか?
03-16-2025 11:32 AM
Как сбросить настрой ки
03-16-2025 11:33 AM
I allready resetted the chromecast! Now it says the iPhone doesnt allow to Connect due too local network? Can you help?
03-16-2025 11:38 AM
What’s up with the “don’t factory reset your device” thing ?!
It’s the first thing that the Google help page asks you to do when you try to troubleshoot your device and now it causes more problems with already broken device ?!
03-16-2025 11:40 AM
Hi, when does the problem result? I ve factory reset one of my device and now i can't use it. Please i need it.
03-16-2025 11:40 AM
Ok...fate al più presto. Grazie
03-16-2025 11:42 AM
Ma perché? Che è successo?
03-16-2025 11:42 AM
Hello, isn't there any solution already?
03-16-2025 11:42 AM
Buongiorno avevo ripristinato il Chromecast e leggendo ho trovato un post che diceva di mettere il telefono alla data del 7 marzo, l'ho fatto e poi con l'app Home sono riuscito a riconfigurare il dispositivo che in seguito si è aggiornato, rimesso la data corretta e tutto funziona perfettamente.
03-16-2025 11:44 AM
Dear Sirs,
unfortunately I reset my Chromecast last week. Please Could you help me? Or could you send me a new chromecast?
looking forward your reply I remain.
Regards.
lara Giussani
03-16-2025 11:47 AM
How long is this going to take???
03-16-2025 11:48 AM
I haven’t received the update! I’ve been triggering with the cast for so long and still won’t let me set it up on my devices
03-16-2025 11:52 AM
cómo hago para actualizar el chromecast si he restablecido a valores de fábrica ??
03-16-2025 11:56 AM
Por favor, cuando van a dar la solución a los que restablecimos a valores de fábrica?
ya llevamos una semana esperando!! Es mucho tiempo
