GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,137 REPLIES 16,137
MJG1959
A bit late with the "do not reset" message. It's the first thing you try when a device like this falls over and stops working so comprehensively. I have two 2nd gen that no longer work but fortunately one 1st gen which I can swap between TVs till you get your act together and sort this out
do not tell this, they will block your 1st gen also Lol
Desertdaz
Me too ... No Chromecast and factor reset using a backdate and still cannot cast. says the Chromecast is offline. Annoying that something that worked so well is now defunct.
eduman
"Are you planning to replace all these devices? I personally own three second-generation Chromecasts, and they were working perfectly fine before your updates. Now they’ve become unusable. Since I didn’t cause this issue, I assume Google will provide replacements — is that correct?"
MP60
is this gonna be resolve or they are just ignoring us. I am so ready to switch to another device. anyway it seems Google can care less. No communication, no fixing, no help whatsoever.
gm3con
I'm very tempted too
Sabby
Oh. Great. I already factory reset it
Olby10
So what? There's been an upgrading of Google Home... but still nothing! It's unbelieveble.!!
alaskaanna
So, my chromecast on bedroom television is not working, but the same exact on in my living room is still streaming and working fine. HOW? IF ONE WORKS THE OTHER SHOULD TOO, I would think, anyways
Are you sure they are both Gen2?
I believe i bought them both at the same time, they look identical.   Pretty sure?
Gen2 looks like this. Gen3 has a "G" instead of the Chrome logo, and a different HDMI cable end.
Did you maybe factory reset one and not the other?
KrishnaMoorthy
Please roll your fix quickly. I hope it shouldn't take any longer to cast from an iPhone, once the fix is released
Olby10
I personally own three second-generation Chromecasts, and they were working perfectly fine before your updates. Now they’ve become unusable. Since I didn’t cause this issue, I assume Google will provide replacements... Do something or I'm gonna switch to another dongle... and ecosystem
Grza
I don't know how you can keep me updated unless I reply here and mark it keep me updated.
Amr2811
Updates ??
ibrahiemsalah
already factory reset my device. What should I do 😭
EugeneCheng
I spent hours trying to fix my wifi, reset the device,  and failed trying to add back the device.  Drove me crazy until I did a lot of searches and came across this.  I hope a fix comes out soon. I use 2 tvs that utilize this daily.    Otherwise google should allow 2nd gen chromecasts be exchanged for the latest model.    They compensated everyone for the Google gaming controllers and games when they discontinued the support for the product.   I'm hopeful they'll do the same for the chromecast.
Joannelynn
Still no update on the fix?
mkeolver
My elderly aunt suffers from Alzheimer's and uses her Gen 2 Chromecast to help her fall asleep, please fix this soon.
shijans
Hello, already made Factory reset to the Chromecast 2 model. Now I can't make an authentication procedure when Chromecast goes to the second screen with the code. What can I do?
tbuz
Change the date of your device, that has your Google Home on it, back to March 8th.  Set your Chromecast up, then change the date on your device back.  Then the factory reset will be undone.
Davidoff
Wie lange dauert das denn bei euch wir würden gerne unsere Geräte wieder benutzen, danke...
ChiloMaco
What is estimated dae of resolution of this problem??
Its unacceptable the time it is taking
CmdrVimes177
Ok, so how long does it take to renew an expired certificate and update your users? I could be wrong but it seems like it should take 30 minutes max. Or is the certificate excuse a convenient smoke screen for something more serious?
Ich denke auch sie stellen jetzt den Support komplett ein, in die Tonne damit und Streaming Dongle gekauft... Ist echt ne Frechheit selbst so ein gewöhnlicher Streaming Dienst stellen sie ein. Haben ja hundert Millionen verkauft und verdient warum dann noch helfen?!
cici1
Has the issue been resolved?
JM60
Why didn't you Goggle inform us NOT TO RESET our device.
Of course I did this in desperation of trying to fix it 😞
WHAT NOW ?
My friend has two of these devices and they started working again yesterday afternoon (GMT) so we're just waiting for the mitigation process for factory reset devices. They just need to get on with it.
Tu amigo tiene de los dispositivos que han fallado?
tbuz
If you factory reset your Chromecast, you can fix it this way. Manually change the date, on the device you use Google Home on, to March 8 or earlier, and you can set up your Chromecast.  Then change the date on your device back to what it should be. You won't be able to use your Chromecast, but it won't be factory reset anymore.
RajeshJha
Hello Team,
Any update or ETA on resolution?
TheHappyGrump
Same issue. Please send out a blanket update when fixed. Killed my treadmill TV. Not happy.
profshakeslock
What is the timeline for a fix update? This is silly.
Iceberg
Same problem here. Looking forward to fixing it.
KoB_2025
If Google doesn’t start communicating, providing updates on this issue and a time line when they think it is resolved, I am inclined to go buy a device from their competition. This is no way to treat a loyal customer.
Any tips on what other device works well, anyone? I read about Fire TV Stick from Amazon? Thanks!
the only defense we have is to make noisy at social media, the image of a company is the 95% of their capital.
That can also be their plan, let's expose Google's terrible posture.
ReyTarzan
They are probably negotiating with cast companies that way they will not aloud you to cast from Netflix etc. Pushing you to acquire new devices.
