GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
Thank you. I've tried this before and it still doesn't allow me to cast only to connect the device unless I follow additional steps to by pass the authentication.
Did it work? I changed the date on the phone after reset,it is there,but the same errors appear when I try to cast...a certain code on netflix,an untrusted device on youtube,nothing happens on max...they ruined this out of negligence or a desperate need for money. It seems billionaires are desperate for more money...
Ho provato,non funziona
yes, you will see it but will not stream, useless work around
WillIV
Not entirely. Having it back on the Internet could help to get an automatic push when Google does release a real fix. Please note this is just a hunch though.
Did this just now. Seems like it at least undid my factory reset. Still unusable.
KBH1
This actually works!!! Wonderful, thanks!
Check your alarms after you   changed the date.. 😉
Jindabyne
Worked too
KBH1
Cheered to soon... connected but no Chromecast icon on my streaming device.. Anyone help???
This helps if you factory reset it
This worked for me. I had done the factory reset as it says at the end of the troubleshooting steps and then was completely unable to add it back in to the network. I set my phone date to 8/3 and then at least I could put the device back on the network.
i still cannot stream to it though.
Worked for me
When I try to reset my phone, then my Disney app, WhatsApp and other apps won't work. I can't even text without my phone having the correct date. So that doesn't work for everyone!
Anonymous
Not applicable
You are not resetting your phone, just manually set the date back to March 7 or prior.
Then open up the Google home application and reset up your chromecast device, at that point your device will be back online just in case google pushes a fix. Then just go back and set the date correctly on your phone and wait for Google to fix it.
Once your chromecast device is connected to your network again even though it's not working completely you can set your phone time and date to normal and just wait for google.
That’s worked to add it back in google home.
a step in right direction
Jgabz
Thank you, this worked for me!
How do you do that?
Yo hice caso de los que aconsejaron cambiar la fecha del celular al 07/03/25 y reconfifugar el chromecast; no tuve problemas con eso.
intenta mirar una pelicola en la TV, no funciona
RCK69
Same here, reset back to factory reset🙄🙄 so now what?
CEinCville
Look for Max 98's reply. He tells how to un- factory reset. Won't allow you to stream but will allow you to undo what Google told us to do and now they're telling us we shouldn't have done 🙄
Exacto tiran la piedra u esconden la mano ..... literal
Reset your phones date to March 8th or earlier. Google home will allow you to finish the setup process. You still won’t be able to stream to it, but at least it won’t be bricked in the setup screen.
Vous pouvez reconnecter Chromecast à Internet en modifiant la date de votre téléphone, à partir du 8 mars par exemple. Vous ne pourriez jamais utiliser un diffuseur, mais si vous l'utilisez aujourd'hui, le chrome coule à l'arrière.
Une fois  reconnecté à Internet, vous pouvez revenir à la bonne date sur votre téléphone.
Anonymous
Not applicable
Yeah...same here, 5x. But to undo your reset (so the device is back at earlier date so that it can be "verified" and connected to your wifi again [and can wait for a solution by Google]) you could apply the following steps:
- Set the clock of your mobile phone manually to March 7 (i.e. at least the day before the problem occured) > Settings clock, date/time > disable automatic date/time setting and change manually to March 7
- Start your Chromecast ("CC") and reset it again
- Now restart the connecting process with CC from Google Home
- The CC will boot up and "verify" with your device again, connect to your wifi again and the stanard screens will show on your TV again
- Now your CC is back alive except for the fact that it won't let you stream anything due to the existing certification problem at Google but it can now wait for Google's fix to come
- Don't forget to switch on "Automatic time/date" of your mobile phone again
Hope this will be of help for now. Best regards from the Netherlands.
Hans
Great advice, thank you. It worked, my Chromecast is now in the previous state, we are awaiting Google to solve the issues. Greetings from România.
That worked! Thanks!
Yvod
Thanks for the step by step. Have reset it, just not awaiting the fix
JSR15
Thank you. Very much appreciated. Now to wait.
Thx HansThis step worked for me. Now Google get your act together so we can actually use the Chromecasts again!
RCK69
I did this, now my other device ( which I gave a factory reset, is back on the screen, but still no casting....
Hopefully its ready for an upgrade, at least...
Thnx a lot for reset advice
WillIV
I'm with you. That's what I'm hoping for too. User tchebb on Reddit has additional steps you can take to get casting again. I'm going to try those after work.
Sagan_Liz
It took me about an hour to work through the instructions, but I was able to get casting again on my phone and computer :).
Souryo
Thank you, it worked. I have it back to my GoogleHome. Now I'm waiting for Google fixing the issues.
Thank you! All 5 Chromecasts are now back to being listed under Devices (under Local Devices for some reason) so here's hoping that means they are ready for the fix. 🙂
Dgedaz
Dankuwel Hans! 👍Now waiting for the issue to be resolved by Google 🤞🤞
Temporarily resetting my phone date to the 8th of March worked for me to get round the Factory reset I did after following the guidance from Google.  So now just got to wait for the idiots who broke it to figure how to fix it.
Yes. I followed their own troubleshooting steps yesterday and it literally says to try a factory reset as one of the steps!!!
Jay2480
Find anonymous’ hack of changing your clock to before March 7. It has worked for me.
Wich clock? How?
