6 wire help
Bbova1
I have a Robert share model ma600. Current wiring is
- white
- green
- black
- yellow
- orange
- red on rh with rc on a jumper
am I compatible?
18 REPLIES 18
Can you post a clearer picture of the terminal block and its labels?
I feel comfortable say it is compatible, but a clearer picture would help
See attached hopefully that’s better. There is a jumper on rc/rh, white, green, yellow, orange, and black and are labelled as such.
Maybe this will be better
 here is a new one sorry for delay…let me know! TY!
@Patrick_Caezza, I appreciate the help!
@Bbova1, thanks for reaching back with a clearer pictures. I can see that it is compatible with Nest Thermostats based on the wire arrangement. Do you mind me asking what type of Nest thermostat do you have?
If you have a Nest Learning Thermostat, use this wiring diagram as your guide.
Also, if you have the newer version of the Nest thermostat, it has 6 terminals. You can follow the same terminals based on the wiring diagram above.
Let me know if that helps.
Google Nest Thermostat - Smart Thermostat for Home - Programmable WiFi Thermostat - model GA01334
Thanks for getting back with the type of Nest thermostat you have. It's called the Nest Thermostat 2020.
It's compatible with your existing wiring configurations, and jumper wires are no longer needed for Nest thermostats. Referring to the wiring diagram above, you can also follow the same terminals where you will connect the wires: W (white is for heating), C (black is for 24V common), Y (yellow for cooling), R (red for power), O/B (orange for your heat pump) and G (green is for fan). Here's your guide setting up your device.
Please let me know if that helps, or if you have any other questions or concerns.
aatienza
I appreciate the help, Mark.
Archie
Bbova1
I have one more question. The thermostat above is for 1 of 3 zones. This is the basement zone. I have thermostats on 1st and 2nd flr as well. The other two thermostats only have 4-wires. RH-Red wire (with the RH/RC connector), W-White wire, Y-Yellow wire, G-green wire. What would be the proper install for these?
Hello Bbova1,
Thanks for getting back. I'd be happy to take a look into this for you.
Nest thermostats don't require jumper wires. If you have 2 power wires connected to Rh and Rc, the Nest thermostat (mirror finished) won't be compatible, but if there was a jumper wire connected from Rh-Rc, you can follow the same wire setup from your other two thermostats with W (white), Y (yellow), G (green) and R (power).
Please note, a Common wire or a Nest Power Connector may require to deliver constant power and stabilizing the flow of current into the thermostats.
Feel free to let us know if you have more questions in mind.
For the 4-wire I don’t see a black common wire. If none is available would I need to run one? Or can I use one of the other 4 wires
Got it. Technically, you can still use the current wire set up. Installing a C wire or Nest Power Connector would avoid future power issues or power loss to your thermostats. Check out these references for how they work:
Give us a shout if you have any questions.
Hi Bbova1,
I know it has been a while but I wanted to ensure that everything is covered here.
How's your Nest thermostat? Were you able to install it? Let us know if you need more help — we're always here.
Best regards,,
Ebedia
@Bbova1 we haven’t heard any updates from you. I’ll go ahead and lock this thread in 24 hours. If you're still in need of assistance, feel free to start a new thread and we'll be happy to help.
I appreciate your response, @mark, @Patrick_Caezza and Archie.
Bbova1
It’s a vaca home I gotta get back over there to try the install again
Ebedia
Hi Bbova1,
Thanks for letting us know. Take your time, I'll be waiting for your update.
Ebedia
Hey Bbova1,
How's it going with your Nest Thermostat? Were you able to reinstall it? You may refer to the links that Mark shared.
Keep us posted.
Hello Bbova1,
It's me again. It looks like you haven't yet installed your Nest thermostat, so I'm going to lock this thread in 24 hours. Please check my responses above for your reference, and if you have any other concerns or questions, please feel free to create a new thread.
