Nest thermostat will not connect with Verizon wifi
Whyisthissohard
We just installed a Nest Thermostat.  It will not connect with wifi nor will it work independently so we can adjust heat.
tinyfactory3
is the wifi 5G? sometimes products have trouble connecting with 5G settings. try the other mode if available and make sure ur apps to control the device is all connecting to same wifi network.
The wifi is 2.4
@tinyfactory3, thanks for the help!
@Whyisthissohard, thanks for reaching out. I'm sorry to hear that you're having an issue with your Nest Thermostat. You mentioned that it's also not working independently. Could you tell us more about this? Are you getting any message on your Nest Thermostat?
Edward
EdwardT
Hey Whyisthissohard,
Edward
EdwardT
Hi Whyisthissohard,
Edward
