connectivity: I tried to reset my two nest thermo.'s and it asks for a code that never comes.
Tommarchetti
RnAElec
the code its asking for?
on your app, or on the thermostats?
Tommarchetti
the code from the nes to the app
aatienza
Tommarchetti, thanks for reaching out. Here's how you can get the entry key from your thermostat:
  1. Press your thermostat’s ring to open the Quick View menu.
  2. Choose Settings.
  3. Turn the ring to Nest app and press the ring to select it.
  4. Select Get Entry Key to retrieve a unique entry key. Follow the next steps below to use your Nest app to add your thermostat to your account.
I appreciate the help, RnAElec.
Archie
aatienza
Archie
aatienza
Hello there,
Archie
