GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Hi @JillG  I had same problem.
Region: Brazil
Model: NC2-6A5
I can see firmware version anymore, because I made factory reset to configure again.
AlexSanfi
Second generation, Spain
System firmware 275994
Cast firmware 1.56.275994
I don't remember the device I used, it's a ChromeCast, probably early generation (grey). UK.
Even worse with a factory reset. Now even VLC won't be able to use it!
Unable to authenticate. looks like a certificate that expired, really not OK!
Kiranp
I am getting this message while setting up "Unable to communicate with the chromecast"
Airlala
Same here
CaroShak
Same, received the following:
Untrusted device. Chromecast couldn't be verified. This could be caused by outdated device firmware.
Did a factory reset, now I'm getting:
We couldn't authenticate your Chromecast. Please visit support.google.com/chromecast for help troubleshooting this issue.
Device: Chromecast 2nd Generation
Region: UK
Firmware Version: Unknown
Guille1
Me pasa lo mismo exactamente  igual
Aninlia
Mine is 3rd gen chromecast, from indonesia using android.
I have done factory reset multiple times, i reinstalled google home app to my 2 android phone. When i tried to add device, 1 phone giving signal and showing setup code but then showing error "we couldnt authenticate your chromecast" and other phone not showing signal and showing "we couldnt communicate"
Having the same problem from yesterday.
Tried factory reset, and no longer able to authenticate Chromecast. Tried making support ticket and system seems down, call back options all fail.
I'm having the exact same problem.  I was streaming TV then suddenly I couldn't cast anymore.  I tried several apps that I cast from and nothing.  So I did like you did, factory reset, deleted the device and tried to re-add and it says "authentication failed".
DebWilly
I am in Australia. Not sure of generation or how to find it.
Something interesting, before I performed a factory reset, the chromecast ambience was still on the screen, with the current temperature, but instead of displaying my home device, (debs_bedroom in my case) it was displaying Google. Could not access any streaming or audio services.
After performing a factory reset authentication failed. I then checked my router and the device debs_bedroom was still displaying in my router. So I rebooted my router and my phone (android) and the device was removed from the router but still an authentication error.
Another factory reset on chromecast and reinstall of Google home and adding device still had same authentication error message when trying to add to the network. Google home found the device but would not authenticate.
I suspect a software update of some kind has created this problem especially with the timing and as so many others are experiencing the same problems.
Looking forward to a solution!!!
Weiyap
Same issue here in the UAE. Exact same steps tried but returned with Authentication Error
NC2-6A5
Not available in Google Home, casting claimed it's an untrusted device. Factory reset now it can't be authenticated
Victoria Australia
Has urs worked yet? I'm in melbs and just turned it on after being away and it's not working.
Lh2025
I'm in the UK using a Chromecast device that is at least 10 years old, I don't know the number. Morning of March 9th it worked fine, yesterday evening and today says it's an untrusted device. I tried resolving it via Google Home to no avail. Unplugged and restarted my chromecast several times. Unplugged and restarted my wifi. Still not working. Thank you in advance for any info.
Lh2025
Also some more info if it helps: the chromecast shows up on my tv but my device (iphone) says it's an untrusted device/ firmware problem.
AnnalisaF
Same error,  not connection,  restarted and than star a new configuration.  Now error to configuration...
Model NC2-6A5
From Italy
Same problem here from Italy. No cast. Reboot. Factory reset. No authentication.
I did all that, too.  In Canada
LuciaC
Yo lo re inicie y ahora ya no puedo establecer la conección de mi teléfono al Chromecast me dice que verifique en el centro de ayuda al usuario y no logro conectar el dispositivo
Me pasa lo mismo, al parecer es algo mundial, por todos los comentarios de este hilo 😧
Rgnb92
Me pasa lo mismo
UK here.  Same problem as everyone.  It's connected on TV but unable to cast.
Cast firmware- 1.56.275994
Everyone asking how to find firmware info-
Go to Home > Devices > choose your chromecast name > Top right corner choose the settings icon (next to 3 dots) > Device information > scroll down to Technical information
Half of us have done a factory reset so our device isn't listed on our app anymore.
Same issue. Getting the authentication error when I am trying to setup the Chromecast after resetting the factory settings.
My chromecast is removed, can not even find it anymore, two of them!
Hi JillG,
Thank you for escalating this issue.
I am from New Jersey, USA.
I tried factory reset and restarting my router. But getting the same authentication error on my Google Home app. I am using an old Chromecast model NC2-6A5. How do I find the firmware version? Home is not showing any option to check this.
I'm from Argentina, I have the same problem. I own several gen2 devices.
Lalyc0
Pense que era la unica desde hoy a la tarde... Espero que lo solucionen pronto.
MagdaL
Te pasó lo mismo con todos o solo con uno? Se te soluciono?
I am also in NJ and having the same issues.
Same after resetting it's not authenticating.
CEinCville
Seems this is happening all over the world. Could my Chromecast device have expired? Worked fine last night. Don't know how to find the details on it to send you. Have unplugged, waited, reconnected, etc even factory reset. Chromecast shows up on my TV but Google home says it's offline, which it clearly is not. I think the problem is with Google home not the Chromecast device.  Tried customer support on the phone got cut off and they won't let me call again.  Can't believe how dependent I am on this product! If it doesn't work I would need to cancel all my streaming services...
Wad4
Indeed. I'm in Lebanon. Chromecast 2 was working just fine a couple of hours ago. Then it stopped communicating with my phone. Tried to unplug, wait, factory reset. But I cannot reset because it cannot "authenticate". Obviously a problem that Google needs to resolve or at least provide feedback on!!
A tech product shouldn't expire! If this is planned obsolescence of the 2nd gen Cromecast then I'm not going out to buy a new one, I'm going to get a competitor's casting device. I don't WANT to do that, though, because I liked my trusty 2nd gen just fine until an hour ago, when I performed a factory reset like the rest of us to poor results. I'm hoping it's an issue with a Google Home app update that can be quickly resolved. Any communication at all from Google could have prevented me from forcing a reset. I feel like the new kid in school getting hazed by being encouraged to check out the pool on the roof.
Airlala
Same here very frustrating
Same here, the chromecast shows up on my tv but my device (iphone) says it's an untrusted device/ firmware problem.
Katte
Same problem here. Hope it’s an outage they are working to patch. I don’t have money to get a new device.
