GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,152 REPLIES 16,152
Anonymous
Not applicable
A mí también me ha funcionado, he puesto una fecha anterior a la del 9 de marzo y he podido recuperar el Chromecast, y se ha actualizado enseguida, muchas gracias!!
nehama
Come si fa a riportare il cellulare ad una data anteriore a questo disastro? Mi puoi spiegare  grazie
Nei
Que genial. Muchas gracias me funciono de maravilla.
Taby55
It worked
I got a Xiaomi and Honor devices some said March 5 but that didn't work for me saw some post about trying the 9th and it worked.
Remember set up the date on your phone or pairing device to March 05 or 09 this year don't go longer or it will loop forever set up your device and enjoy.
Bvpee
Opgelost.. mooi zo . Thx
Anonymous
Not applicable
Résolu ?  Ta chromecast a reçu la mise à jour ?
Actually, at least in my case, the fix is received when you turn the chromecast on.
I had them on for since yesterday and nothing. They both were updated AFTER I turned them off and on again.
Nouni
Hello, I factory reset my chromecast then applied the date setting technique and it was reinstalled and it downloaded an update which took a few minutes, but it still won’t work, so do I have a problem or is the fix not released yet
jjasond
I had the same experience when attempting this fix via android. Chromecast playback only worked after changing my date and time Settings back to auto again.
I factory reset mine before the fix but managed to set it up again by changing the date of my android phone to a date before the 9th of March. It still did not work right away but today all my Chromecast audios including that one started working again.
Ckama
Thank you 💜
Zap2too
I did the same but it won't connect to the wifi.
Thanks for posting this - I had done a factory reset as well so when I changed the date it did the update it is now working fine after I changed the date back. 👍👍
Rose59
How too change the date?
Snoozy
I did the same - did the factory reset before I saw the issue. Changing ghe date worked for me, once connected to wifi the update downloads and now it works. Thank you.
AVis
This worked for me too. I also went through the factory reset. Reset the date of my tablet, connected it on wifi, kept the chromecast online all night and now it is working again.
I did the same thing but can't find the hack. Do I just change the date on my phone to March 9 and it will update my cc?
Set you phone date back to before the problem occurred, I used March 5th, you can then re join your Chromecast to your network, then leave it for an hour or so and the patch should download, don’t forget to set your phone date back to auto.
SBMB64
@Chris-S how do I change the date on my phone?
EKOM
Go to time settings
Turn off automatic time.
Set the new time.
Ckama
Thank you
Frasa54
Grazie mille, ha funzionato.
Penny79
Thank you!! It worked!!
Thanks so much!!
No you are not.
On your phone, the one that connects to the chromecast, change the date to march 8th. If you do that, you will be able to configure the device. After that, just wait a couple of hours and it will start working again.
I had factory resected my device and that was what I did and now it's working perfectly.
Wonderful !! date change - perfectly worked, it also took the updated when configuring... thank you
EKOM
This!!!!! This worked!!!! THANK YOU!!!
Brother, you are god
Amigo, você e um gênio
Crack, sos alto gato
Na mosca kkkkk deu certo podem fazer rapidinho já conecta!
meu deus funcionou, finalmente vou ser feliz novamente! 🙏🏼 tenho dependencia emocional no chromecast OBRIGADA AMIGO
You can set up the Chromecast again by setting your phone date back to 5th march, complete the set up to make it active, and then correct your phone date once done. The Chromecast is at least active to accept the update. It's worked for me so hope it helps someone else too.
It worked for me, thanks!!
Mine was factory reset and I couldn’t get it set up again, but changing the iPhone’s date to March 5th and starting the setup from scratch, allowed me to configure the Chromecast, and it connected and downloaded the latest firmware and I’m back in business!
Anonymous
Not applicable
Brilliant! I have android - i changed to 5th March and wow it works - thank you so much! xxx
csabex
Thx Anna, this has worked for me too 🙂
Kaell
Levi 8556
Kaell
Joao8556
Io ho fatto lo stesso con il mio S23 android ed è ok
Che significa? Cosa dovrei fare? Cambiare data sul mio cellulare?
Beato te, woooooooow, ma dammi una dritta.......
  • Show friend, it worked very well. After resetting the date to 03/05/2025, we were able to configure it and get updates in CHROMECAST and IT WORKED. With the date changed, it didn't identify what you said CHROMECAST did. But when I returned to today's date, it connected to Netflix. CONGRATULATIONS to you, Google is a piece of crap.
  • YOU SHOULD FIND THIS IDEA FROM YOUR FRIEND, Valweebo, top.
