Home Automation
The latest updates from Google Home and Nest Read more
Help Center
The voice command doesn’t work.
Hello everyone, Since July, it has not been possible to activate my house gate with the voice trigger.I have an automation set up to activate the routine, but Gemini says: ‘No automation is configured at the moment.'Do you have a similar problem?Many...
Gen 1 & 2 to be disconnected from nest/google apps
it is terrible that I just learned Google and nest apps would disconnect our gen2 thermostats. This is terrible because I don’t want to throwaway working devices and their deadlines are so soon when I will be out of town for a period of time. This se...
Odia1 by Community Member
  • 40 Views
google nest no longer recognises nanoleaf
Google home is no longer recognizing the nanoleaf app as existing at all, I am unable to add or delete it in the app and therefore unable to control my lights at all, except for the matter enabled ones. please help
Gree Air conditioner
I have 3 gree AC units, all 3 were working, I switched internet providers and 2 them kept working just fine but the 3rd one will not connect, it just won’t let me connect
Mdz by Community Member
  • 58 Views
Lenovo Smart Clock 2 won't display all photo's
So, my smart clock (the Lenovo Smart Clock 2) isn't displaying all photos, i've contacted Lenovo about it, and told me that since google created the firmwear and such, you would be able to provide the exact compatible resolution that works with the c...
Will23 by Community Member
  • 117 Views
Google Nest WiFi Pro Point
Trying to hook up my Nest WiFi Pro points, I’ve already set up the main router which is hooked up to my ISPs modem, when I try and add a new point by adding a device in the google home app I get this error code at the end of the process once it tries...
jrv1 by Community Member
  • 112 Views
Done with Nest
Google has screwed me and many others. Sensi thermostat will be my replacements.
GL66 by Community Member
  • 125 Views
